PROBLEM
Not prompted for user name and password or version when opening a partial SDE connection file
If two or more SDE connection files are active in an ArcMap or ArcCatalog session, the connection file that contains saved user name/password or version information is used, even if the other SDE connection file does not contain saved user name/password or version information.
Cause
ArcCatalog saves connection information in a binary connection file called an SDE connection file (*.sde). Connection files can be created through the Add Spatial Database Connection tool in ArcCatalog. When creating a connection file, it is the user's choice to save both the user name/password and version information with the connection file. If these properties are not saved, the connection file is referred to as a partial connection file.
When a partial connection file is used to establish a database connection, ArcGIS prompts the user to enter the missing properties. However, if there is an existing connection to the same ArcSDE geodatabase in the ArcMap or ArcCatalog instance, any subsequent partial connection matching the original server, instance, and authentication mode properties, uses the original connection properties. If the user connects to an ArcSDE geodatabase with a partial connection file, such as missing user name/password or version, and there is already a connection to the same server and instance, the user is not prompted to fill in the missing properties; the properties from the original connection are used instead.
Solution or Workaround
Make two different connections to the same server/instance pair by creating two separate SDE connection files, saving both user name/password and version in each.
If the connection-prompting behavior is desired, close all connections to SDE in the ArcCatalog process and open the partial connection file. The same logic applies for map documents. If the user name/password or version properties cannot be saved in the connection file, only add layers to the map from one partial connection file. That way, when the map document is opened, the user is prompted to enter the missing connection properties.
    Article ID:000009419
    Software:
    • Legacy Products
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
