ERROR
ORA-20603: Spatial References are not compatible (from ST_Transform)
Error Message
SQL> select st_transform(shape,51)
  2  from parks_st
  3  where objectid = 1;
ERROR at line 1:
ORA-20603: Spatial References are not compatible.
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 752
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 1882
Cause
If the datums of the source and destination spatial references are different, then ST_Transform fails with the error referenced above.
This is true of the implementations of ST_Transform on Oracle, IBM DB2, and IBM Informix.
Solution or Workaround
Only use ST_Transform with source and destination spatial references that have the same datum.
Article ID:000009416
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
