BUG
ArcMap crashes when switching the selection after data is joined
ArcMap crashes when switching the selection after data is joined.
Cause
This is a known issue, specific to .dbf and file geodatabase tables.
Workaround
Import the tables into a personal geodatabase, then join and make selections.
    Article ID:000009377
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
