ERROR
Error 1904. Module C:\Program Files\ArcGIS\bin\Scene.dll failed to register
Error Message
The following error message displays when installing ArcGIS Engine silently using the ADDLOCAL property:
"Error 1904. Module C:\Program Files\ArcGIS\bin\FileName.dll failed to register."
Cause
The Microsoft System files are required. The Microsoft System files are included in the Engine Runtime setup as a hidden feature. When using the ADDLOCAL property to list specific features, the feature MicrosoftMSM must also be listed.
Installing with ADDLOCAL=ALL to install a complete setup, or omitting ADDLOCAL to install a typical installation, automatically includes the Microsoft System files.
Solution or Workaround
Use the following silent install command:
Code:
msiexec.exe /I D:\Engine\setup.msi /qb ADDLOCAL=ArcEngine,MicrosoftMSM,DotNetRuntime
Change the "D:\Engine\setup.msi" to the location of the ArcGIS Engine Runtime setup.msi file.
    Article ID:000009372
    Software:
    • ArcGIS Engine 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
