English
Problem: ArcGIS Server 9.2 on Linux does not restart automatically after the server machine is rebooted
ArcGIS Server 9.2 on Linux does not restart automatically after the server machine is rebooted.
Cause
The startup scripts for ArcGIS Server 9.2 are not placed at the correct system run level.
Solution or Workaround
  1. Log in as a root user and delete the link named 'S99serverobjectmanager' from the following location:
    /etc/rc2.d
  2. Delete the link named 'S99mwcoreservices' from the following locations:
    /etc/rc3.d
    /etc/rc5.d
  3. Delete the link named 'K70mwcoreservices' from the following locations:
    /etc/rc0.d
    /etc/rc1.d
  4. Create a symbolic link in /etc/rc3.d and /etc/rc5.d
    named 'S99serverobjectmanager' that points to the following script:
    arcgisserver_install_location/servercore/.Server/agsserver
    For example:
    Code:
    > ln -s arcgisserver_install_location/servercore/.Server/agsserver S99serverobjectmanager
  5. Create a symbolic link named 'K99serverobjectmanager' to arcgisserver_install_location/servercore/.Server/agsserver in following locations:
    /etc/rc0.d
    /etc/rc1.d
    For example:
    Code:
    > ln -s arcgisserver_install_location/servercore/.Server/agsserver K99serverobjectmanager
