ERROR
FATAL ERROR Cannot delete argument file (ARGEXE)
Error Message
Running an ARC Macro Language (AML) gives the following error message:
"FATAL ERROR
Cannot delete argument file (ARGEXE)"
Cause
1] The account that logs in to the server loses its environment setting upon log in when running an AML.
2] Running the AML on a workstation with a dual core processor.
Solution or Workaround
  1. Solution for cause 1]:
    Reassign the environment variables in a login script for the user account.
  2. Solution for cause 2]:
    Install an older version of BIOS, such as A00, that allows the second processor to turn off.
Article ID:000009323
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
