English
Error: Error 1904: failed to register C:\Program Files\ArcGIS\Bin\sketchupreader.dll
Error Message
When installing ArcGIS Desktop 9.2, the following error message is displayed:
Error:
Cause
The file atl.dll is not properly registered.
Solution or Workaround
  1. Click Ignore on the 1904 error message dialog box.
  2. Manually register atl.dll. To do so, refer to the steps provided in the following article, Error 1904: Failed To Register AoInitializer.dll.
  3. Using the same procedure shown in Step 2, change directory to <arcgis_install_location>\bin and manually register sketchupreader.dll:
regsvr32 sketchupreader.dll
