ERROR
Invalid Topology [NO_INFO_ADDITEM] Failed to execute (FeatureclassToCoverage_1)
Error Message
When converting a feature class to a coverage, the following error message is displayed:
"Invalid Topology [NO_INFO_ADDITEM]
Failed to execute (FeatureclassToCoverage_1)."
Cause
This failure occurs when the maximum of 4096 bytes per table is reached.
For example, a shapefile that has 17 text fields, each 254 in length, and two date fields, which, when translated to an ArcInfo coverage, take 8 bytes each. The total number of bytes for this table is (17 x 245) + (2 x 8) = 4334 bytes, which exceeds the ArcInfo Workstation INFO limit of 4096 bytes per table.
Solution or Workaround
Remove fields from the shapefile until it is under the 4096 byte limit.
    Article ID:000009293
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
