English
Bug: All layers in a group layer disappear when printed or exported from ArcMap
All layers in a group layer disappear or do not display properly when the map is printed or exported from ArcMap.
Cause
This is a known issue when the group layer is set with transparency - a new feature at ArcGIS Desktop 9.2.
Workaround
Remove group layer transparency and set transparency on each individual layer in the group layer.
