English
Bug: Review/Rematch Address dialog displays zeros for all statistics even when matches are displayed in the map
The Review/Rematch Address dialog displays zeros for all statistics. However, any matches display as points on the map and the AV_Status field is populated in the attribute table.
Cause
The output file format of the geocoding results is a shapefile that includes invalid characters in the file name.
Workaround
Rename the shapefile so that it does not start with a number, contain spaces or invalid characters (- # /). Underscores ( _ ) are valid characters that can be used instead of a space.
Related Information
