PROBLEM
Various dialogs boxes show up as boxes and squares instead of displaying the correct text
When working in ArcGIS Desktop, various dialog boxes and taskbars display in place of the expected text.
Cause
This is a Microsoft issue that typically occurs if Mfc40loc.dll is installed on the system.
Solution or Workaround
Rename Mfc40loc.dll.
This information was provided from the Microsoft website. For more information, see the link in the Related Information section below.
  1. Right-click on Start and select Search. Click All Files Or Folders.
  2. In the Search box, type 'Mfc40loc.dll' without the quotes. In the Look in box, click to select the hard drive where Windows is installed, then Click Find Now.
  3. Click to select the Mfc40loc.dll file in the Results pane. Right-click on the Mfc40loc.dll and select Rename. Rename the file to Mfc40loc.old.
    If Mfc40loc.dll is not on the hard drive, try searching for the file named mfc42loc.dll and repeat the above steps.
Article ID:000009231
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
