English
Problem: ArcGIS Desktop 9.2 installation hangs at 0 seconds
The ArcGIS Desktop 9.2 installation hangs at 0 seconds.
Cause
The application RepairGIOApps.exe is causing the installation to hang.
Solution or Workaround
Stop the RepairGIOApps.exe process. If this does not work, please contact ESRI Support.
  1. Allow the installation of ArcGIS to proceed until it hangs at 0 seconds.
  2. Press the keys CTRL+ALT+DEL and click the Task Manager button.
  3. Select the Processes tab.
  4. Locate RepairGIOApps.exe, right-click on it and select 'End Process Tree'.
  5. Allow the installation to finish.
