ERROR
java.lang.NullPointerException at javax.faces.webapp.FacesServlet.init(FacesServlet.java:144)
Error Message
When viewing Web Mapping applications deployed on Tomcat version 5.5.20, the following error is displayed:
"java.lang.NullPointerException at javax.faces.webapp.FacesServlet.init(FacesServlet.java:144)"
Cause
This is a known issue with the 5.5.20 distribution of Apache Tomcat.
Solution or Workaround
  1. Add the following to the <Tomcat Folder>\webapps\<web app name>\WEB-INF\web.xml file:
    Code:
    <listener>
    <listener-class>com.sun.faces.config.ConfigureListener</listener-class >
    </listener>
  2. Re-start the Tomcat service.
Article ID:000009212
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
