ERROR
Error 1500. Another installation is in progress
Last Published: November 9, 2020
Error Message
This article pertains to ArcGIS versions 9.x and 10.0. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
The following error message is displayed when trying to install:
Error:
Error 1500. Another installation is in progress. You must complete that installation before continuing this one.
Cause
The installation process stops responding.
Solution or Workaround
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
  1. Select Start > Run, type regedit and click OK to start the Registry Editor.
  2. Locate and delete the following subkey in the registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\InProgress
  1. Close all windows and restart the computer.
  2. Start the installation process again.
Article ID:000009184
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
