BUG
After adding two or three SDC1 datasets, the following error message is displayed:
"ArcMap has encountered a problem and needs to close."
SDC1 datasets are found on the ESRI Data & Maps discs from 2003 or 2004.
Newer ESRI Data & Maps discs have a newer revision of the data that does not cause the problem.
Earlier versions of SDC, found in older ESRI Data & Maps media kits, are incompatible with newer versions of ArcGIS.
Get help from ArcGIS experts
Download the Esri Support App
