PROBLEM
Services do not start when the LAN connection has failed to the ArcGIS Server or if the LAN cable is disconnected from the Server.
This is commonly seen when ArcGIS Server is installed on a laptop for testing or demonstration purposes.
When a service is created by browsing to a shared .mxd document in Server Manager, ArcGIS Server is using an UNC path to the document.
Microsoft Windows has a known limitation that does not allow a machine to use UNC paths when it does not have an active LAN connection.
Get help from ArcGIS experts
Download the Esri Support App
