ERROR
Unable to export Web application
Error Message
When exporting a web application from the ArcIMS Java Web Manager, the following error message is displayed:
"Unable to export Web application [web application name]"
Cause
This is a known issue with 9.2 Final & SP1 version of the ArcIMS Java Web Manager.
Solution or Workaround
  1. Navigate to <ArcIMS install directory>\java\web_output.
  2. Under the web_output directory, add a new directory named 'applications'.
  3. Restart the computer.
Article ID:000009153
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
