English
How To: Populate a newly created annotation class in feature linked annotation with attributes from existing features
Summary
Instructions provided describe how to populate a newly created annotation class in feature linked annotation with attributes linked to the class.
Procedure
When adding a new annotation class to any feature linked annotation, pre-existing features in the feature class that the annotation is linked to do not have their corresponding annotation added. Use the following procedure to add the annotation for these features:
  1. Add the feature class and its linked annotation class to an ArcMap document.
  2. Select the features in the feature class whose annotation needs to be populated.
  3. Right-click on the layer for the selected features in ArcMap's Table of Contents and select Selection > Annotate Selected Features.
  4. Specify the desired annotation class or classes to populate.
