English
Error: Spatial reference does not match map's
Error Message
When running a Geoprocessing Task in the Web Mapping Application, the following error message is displayed in the Results panel:
"Spatial reference does not match map's"
Cause
The Geoprocessing Task is attempting to output data into a spatial reference that is different than the map's spatial reference.
Solution or Workaround
If the geoprocessing service is set to output data, the data must be output to a spatial reference that matches the spatial reference of the map in the Web Mapping Application.
There are two ways to accommodate this requirement of the ArcGIS Server Web Mapping Application:
  • Set the Geoprocessing Task output to have its 'Output Spatial Reference' set to 'Same as Input'.
  • Ensure the map resource that is displayed in the map has the same spatial reference as the output from the Geoprocessing Task.
