is required to Enable Archiving on a dataset and to perform the archive operation. The archive operation occurs when edits are saved or posted to the DEFAULT version for any feature class that has archiving enabled. On these operations, the GDB_HISTORICALMARKERS DEFAULT marker is updated with the current O/S time.
is required to view any historical marker, including the DEFAULT historical marker, using the Geodatabase History Viewer.
