BUG
Index_mask for SE_table_rebuild_index is not defined in SDE C client
A C-API program that rebuilds indexes on tables using SE_table_rebuild_index cannot be compiled even though it uses a valid index mask.
Supported index masks include:
SE_INDEX_RASTER - Rebuilds the indexes for the Raster tables.
SE_INDEX_SPATIAL - Rebuilds the spatial index table.
SE_INDEX_XML - Rebuilds the XML indexes.
SE_INDEX_VERSIONED - Rebuilds the indexes for the Adds and Deletes tables.
SE_INDEX_ALL - Rebuilds all valid indexes on the ArcSDE table.
The compile fails with the following error message:
"Index_mask for SE_table_rebuild_index is not defined in SDE C client"
Cause
The index mask constants are not defined in the ArcSDE C-API include files.
Workaround
To compile and build a program that uses SE_table_rebuild_index, define the following constants in the code:
Code:
#define SE_INDEX_RASTER (1)
#define SE_INDEX_SPATIAL (1<<1)
#define SE_INDEX_VERSIONED (1<<2)
#define SE_INDEX_XML (1<<3)
#define SE_INDEX_ALL (1<<4)
Article ID:000009122
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
