PROBLEM
There are several scenarios in which ArcGIS Snippets have problems in the Visual Studio 2005 (VS2005) from the .NET SDKs. The solution for all of the undesired behavior is the same. The following list illustrates the different behaviors:
1. When opening VS2005 a message appears "Indexing Code Snippet folders..." that takes a long time to process and VS2005 seems to run slowly.
2. When inserting an ArcGIS Snippet by right-clicking in the VS2005 code editor and selecting 'Insert Snippet', the option for ArcGIS Engine and/or ArcGIS Desktop repeats itself several times.
3. When inserting an ArcGIS Snippet by right-clicking in the VS2005 code editor and selecting 'Insert Snippet', the option for ArcGIS Engine and/or ArcGIS Desktop appears. When selecting a snippet to insert, nothing is inserted.
Either the .NET SDK (Desktop or Engine) has been installed multiple times or the ArcGIS snippets have been deleted from the hard drive.
ArcGIS Snippets are just XML files that get read and portions are inserted into the VS2005 code editor. The VS2005 IDE keeps track of all snippets that are installed on the system in an index file. This index file is maintained wholly by VS2005. Performing an uninstall/reinstall of any 9.2 .NET SDK, moving or renaming of any ArcGIS Snippets causes the index file to get out of sync and causes the problems described above.
The snippet index file automatically regenerates the next time VS2005 opens.
Get help from ArcGIS experts
Download the Esri Support App
