PROBLEM
Feature editing fails in an editable layer
When editing layers, features from an editable layer are not editable.
Cause
When using query filter, only a subset of fields contained in the feature layer is returned. For example:
Code:
using (FeatureDataReader reader = featureLayer.GetDataReader(new QueryFilter(new Envelope(e.MapCoordinate,
map1.ToMap(3),map1.ToMap(3)), EsriGeometricRelationship.Intersect),"tempfield", featureLayer.GeometryColumnName))
if (reader.Read())
reader.SetInt32(reader.GetOrdinal("tempfield"), 1); // throws an exception
reader.Update();
Solution or Workaround
To avoid this problem, do not restrict attribute fields to be returned within a query. For example:
Code:
map1.ToMap(3),map1.ToMap(3)), EsriGeometricRelationship.Intersect)))
if (reader.Read())
reader.Update();
    Article ID:000009048
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
