PROBLEM
Compression set in the Raster Storage Environment Settings is not working for the Mosaic to New Raster model tool
The Raster Storage Environment Settings can be set for geoprocessing tools that have a raster dataset as an output. One of the storage settings available is the compression setting.
When using the Mosaic to New Raster model tool, the compression setting is not working.
Cause
This tool is based on the Create Raster Dataset tool. By default, the Create Raster Dataset tool is set with LZW compression.
Solution or Workaround
Create a raster dataset and use the Mosaic tool.
If the LZW compression is acceptable, continue to use the Mosaic to New Raster model tool.
  1. Use the Create Raster Dataset tool to create an output raster dataset within a personal or file geodatabase by navigating to ArcToolbox > Data Management Tools > Raster.
  2. Click the 'Compression (optional)' drop down and select the appropriate compression.
    [O-Image] Compression
  3. Once the raster dataset has been created, mosaic the raster datasets via ArcToolbox > Data Management Tools > Raster > Mosaic.
  4. Specify the Target Raster as the raster dataset.
Article ID:000009046
Software:
  • Legacy Products
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
