HOW TO
View TIFF images in Microsoft Document Imaging (MDI) generated by sderaster
Last Published: January 5, 2021
Summary
TIFF files written by sderaster store data from a different band separately, instead of interleaved by pixel. Microsoft Office Document Imaging uses Microsoft Document Imaging Format, a file format based on the Tagged Image File Format (TIFF) that is designed to store images by page layout.
The sderaster command writes a valid TIFF format that can be read by most TIFF readers; however, Microsoft Document Imaging cannot read TIFF files that are formatted this way.
ArcSDE software, including the application server, command tools, and SDK with C and Java APIs, was deprecated at ArcGIS 10.2.2 and is no longer distributed. ArcGIS software features were deprecated, rather than immediately removed, to provide customers with backward compatibility and give as much advance notice as possible to adopt newer technology.
Procedure
Instructions provided describe how to view TIFF images generated by the sderaster command in Microsoft Document Imaging.
  1. Load the TIFF image into ArcMap/ArcCatalog.
  2. Right-click the image and select Export Data to export the TIFF file to a TIFF with another name. Make sure the exported format is TIFF.
tiffcp (a tool that comes from the libtiff.org library) can also be used to change the pixel layout from separate to interleaved.
Article ID:000009042
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
