Frequently asked question
Why are there black artifacts corresponding to areas where my source raster has no data?
Answer
Mobile ADF raster implementation support supports layers, but not color key transparency. As a result, two layers can be blended by making one of them semi-transparent. It is not possible to assign transparency to one value; for example, ‘no data’.
To avoid seeing black artifacts in areas where an image has no data, use raster that has data throughout the extent. Also, turn layers on and off depending on whether it obscures visibility and the use of other layers.
Article ID:000009033
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
