English
How To: Manually place unmatched records after geocoding
Summary
Instructions provided describe how to manually place points for unmatched records after geocoding addresses. The workflow differs depending on the version of ArcGIS for Desktop being used.
Procedure
In ArcGIS Desktop 9.x:
1. Start an Edit session.
2. Set the task on the Editor toolbar to Modify Feature and the target to the geocoded layer.
3. Open the attribute table of the geocoded points and select/highlight the record to be placed.
4. In the Status field, change the U to an M for the selected record.
5. Place the point using the Sketch tool by clicking on the map at the desired position. The placed point assumes the attributes of the record whose U value was changed to an M.
In ArcGIS for Desktop 10.x:
2. Open the attribute table of the geocoded points and select/highlight the record to be placed.
3. In the Status field, change the U to an M for the selected record.
4. Place the point using the Edit tool by dragging the existing point on the map to the desired position.
