English
Problem: North arrows do not display when viewing a Java ADF web mapping application
North arrows in a web mapping application does not display correctly on Unix/Linux platforms.
Cause
The Unix/Linux platform that the Web Application Server is running on does not have the ESRI TrueType Fonts installed.
Solution or Workaround
Install the ESRI True Type Fonts. See the link in the Related Information section below.
    Related Information
