English
Bug: Run-time error 91 occurs after exiting ArcMap
When exiting ArcMap, the following error displays:
"prjTableReview
Run-time error '91'
Object variable or With block variable not set.
Runtime error '440': Automation error."
Cause
This is a known issue.
Workaround
This issue is addressed in PLTS 9.1 Foundation Service Pack 3 (SP3). See the link in the Related Information section below.
    Related Information
