Frequently asked question
Convert units for use in Military Analyst Geodesy API
Answer
Military Analyst's Geodesy API accepts units in meters. All other units must be converted to meters before use. The conversion is done using the IUnitConverter interface in the esriSystem library. For example, to convert 10 meters to nautical miles:
Code:
Dim k As IUnitConverter
Set k = New UnitConverter
Dim j As Double
j = k.ConvertUnits(10, esriMeters, esriNauticalMiles)
Other units for conversion are:
Code:
esriUnknownUnits 0 Unknown
esriInches 1 Inches
esriPoints 2 Points
esriFeet 3 Feet
esriYards 4 Yards
esriMiles 5 Miles
esriNauticalMiles 6 Nautical miles
esriMillimeters 7 Millimeters
esriCentimeters 8 Centimeters
esriMeters 9 Meters
esriKilometers 10 Kilometers
esriDecimalDegrees 11 Decimal degrees
esriDecimeters 12 Decimeters
esriUnitsLast 13 Internal use only
To convert from US Survey feet, instead of the default International Feet, multiply by 1200/3937 to obtain meters. Input the results into the function above.
Article ID:000008994
Software:
  • ArcMap 9 x
  • ArcGIS Engine 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
