Frequently asked question
If the ArcIMS server is running without problems or not experiencing problems with any bugs that are fixed in the newer version, then there is no need to upgrade to the new ArcIMS version, and no need to upgrade the Web server and servlet engine. However, an upgrade is strongly recommended if other ESRI products of the newer version are installed on the network. It is strongly recommended to keep all ESRI products at the same version level.
Get help from ArcGIS experts
Download the Esri Support App
