English
Problem: The GPS device is connected but no data is being received in the GPS Position window
After clicking the 'Detect GPS Port' button and 'Test Connection' button on the GPS Connection Setup dialog box, data does not appear in the GPS Position window.
Cause
Even though the GPS may be connected correctly, it is necessary to open a connection to view the incoming data.
Solution or Workaround
Click the 'Open Connection' button on the GPS Toolbar to view the incoming data from the GPS unit.
