English
How To: Avoid stopping an ArcIMS server when needing to edit a shapefile used in a map service
Summary
Instructions provided describe how to avoid stopping an ArcIMS server when needing to edit a shapefile used in a map service since the ArcIMS Spatial Server locks shapefiles so that they cannot be edited by other applications.
Procedure
  1. Stop the map service.
  2. Delete the map service.
    If the shapefiles are in use by other map services, those map services also need to be deleted before performing step 3.
  3. Make the edits to the shapefile(s).
  4. Re-add the map service.
  5. Start the map service.
Related Information
