English
How To: Create a line based on origin and destination points with Python
Summary
Instructions provided demonstrate one method for creating a line feature between origin and destination point XY coordinates from a table using the Python scripting environment.
Procedure
This article contains a sample table and script that demonstrates one method for creating a line feature between an origin and destination point XY coordinates from a table.
  • The script creates a feature class, defines the coordinate system and then uses the information provided in the table to populate the feature class with the line geometries in ArcGIS 9.2 or higher release:
    Code:
    import sys, string, os, arcgisscripting
    gp = arcgisscripting.create()
    gp.Overwriteoutput = 1
    #Specify the location for the new shapefile.
    gp.CreateFeatureclass("C:/temp/", "test_line.shp", "POLYLINE")
    #Define Coordinate System
    gp.workspace = "C:/temp/"
    gp.toolbox = "management"
    coordsys = "Coordinate Systems/Geographic Coordinate Systems/North America/North American Datum 1983.prj"
    gp.defineprojection("test_line.shp", coordsys)
    #Open a cursor to insert rows into the shapefile.
    cur = gp.InsertCursor("C:/temp/test_line.shp")
    #Create an Array and Point object.
    lineArray = gp.CreateObject("Array")
    pnt = gp.CreateObject("Point")
    #Open a cursor on the table of XY coordinates to read from.
    rows = gp.SearchCursor("c:/pythonTest.dbf")
    #Reset the cursor to the top.
    row = rows.Next()
    #Loop through each record in the XY table..
    while row:
    #Set the X and Y coordinates for origin vertex.
    pnt.x = row.GetValue("Origin_x")
    pnt.y = row.GetValue("Origin_y")
    #Insert it into the line array
    lineArray.add(pnt)
    #Set the X and Y coordinates for destination vertex
    pnt.x = row.GetValue("dest_x")
    pnt.y = row.GetValue("dest_y")
    lineArray.add(pnt)
    #Go to next row in table.
    row = rows.Next()
    #Insert the new poly into the feature class.
    feat = cur.NewRow()
    feat.shape = lineArray
    cur.InsertRow(feat)
    lineArray.RemoveAll()
    del cur, row, rows
  • The formatting of the source table should include X and Y data for both the origin and destination points.
    [O-Image] Points
  • The script can be expanded to process the output feature class in various ways. A few examples are adding fields and calculate values, appending the new values to an existing feature class, or adding features to an existing topology.
  • The sample code is slightly different for versions of ArcGIS prior to version 9.2:
    Code:
    import sys, string, os, win32com.client
    gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
    row = rows.Next()
    while row:
    lineArray.add(pnt)
    lineArray.add(pnt)
    row = rows.Next()
    feat = cur.NewRow()
    cur.InsertRow(feat)
    del cur, row, rows
