PROBLEM
Modeling surfaces often requires the use of more than one surface for the area of interest. If more than sixty TINs are added to ArcScene, the application fails with the following error:
"The instruction 0x0000000 referenced memory at 0x0000000 which could not be read."
This is a known issue.
Get help from ArcGIS experts
Download the Esri Support App
