ERROR
When running Tabulate Area, the following error message is displayed:
"An error was encountered while executing TabulateArea.
("esriGeoAnalyst.GridEngine") Could not open raster dataset from file
Failed to execute"
When running Zonal Statistics or Zonal Statistics as Table, the following error message is received:
"An error was encountered while executing ZonalStatistics.
("esriGeoAnalyst.GridEngine") Grid has no VAT
Failed to execute"
This article applies to these tools only when a shapefile is used for the Feature Zone Data.
The range of values for the Zone field exceeds 100,000. For example, one attribute is 800,000 and another attribute is 200,000.
Get help from ArcGIS experts
Download the Esri Support App
