English
Problem: Snapping dialog does not appear with any shapefiles or checkboxes
The snapping dialog does not show any shapefiles or checkboxes.
Cause
The Windows registry has been corrupted.
Solution or Workaround
Restore the snapping dialog by removing current user ESRI settings in the registry.
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
  1. Close any open ArcGIS applications.
  2. Navigate to Start > Run, type regedit and click OK.
  3. Expand HKEY_CURRENT_USER > Software.
  4. Right-click the ESRI folder and select Delete.
