HOW TO
Instructions provided shows how to create a time attribute for a network dataset when a MPH and Length field exist.
Note: In this example, the Length_field must be in units of miles for this formula to return the correct time values.
[Length_field] / [MPH_field] * 60
The time is provided in minutes using this formula. It is usually necessary to adjust for another value. For example, multiply by 60 again to receive the time in seconds.
Get help from ArcGIS experts
Download the Esri Support App
