English
How To: Create multiple hyperlinks for one feature
Summary
Instructions provided shows how to create multiple hyperlinks for one feature.
Procedure
  1. From the Standard toolbar, click on the Identify tool. Click on a feature to identify it. The Identify Results dialog box opens.
  2. In the Identify Results dialog box, right-click on the primary display field value under the layer name. Select 'Add Hyperlink...'.
    [O-Image] O-Identify
  3. Browse to document. Alternatively, type in a URL.
    [O-Image] Add Hyperlink
  4. Repeat the above steps as many times as needed.
  5. There are two methods (Methods A and B) to view the hyperlinks:
    Method A:
    1. Select the Hyperlink tool. Left-click the feature that the hyperlinks are applied to.
    2. The Hyperlinks dialog box opens to a list of the hyperlinks. Select a hyperlink and click 'Jump...'.
    [O-Image] O-hyper
    Method B:
    1. Select the Identify tool. Click the hyperlinked feature.
    2. Right-click the primary display field value under the layer name. Highlight 'Hyperlinks'. Click a hyperlink.
    [O-Image] O-identify2
