PROBLEM
The Batch Project Script has a limit of 2000 characters in the string that specifies the path to the data and the names of the input feature classes
** This problem was resolved at ArcGIS version 9.2 **
The Batch Project Script, located in ArcToolBox > Data Management Tools > Projections and Transformations > Feature fails with the following error:
[O-Image] [O-image] Batch Project Script error
Cause
The Batch Project Script is limited to a total string of 2000 characters for the path to the input data and the names of all feature classes being projected.
Solution or Workaround
Try the following workarounds:
  • Place the data to be projected in a location with a short path.
  • Rename feature classes being projected with shorter names.
  • Reduce the number of feature classes being projected in a single batch process.
Article ID:000008843
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
