English
Bug: Buttons do not appear when using Add Map Series, Add Simple Map Series, or Create Visual Extent Map Sheet
When using MPS Atlas, the Back, Next, and Cancel buttons do not appear on the Add Map Series or Add Simple Map Series wizards. The OK and Cancel buttons do not appear when using Create Visual Extent Map Sheet.
Cause
The Display Properties of the computer have a DPI setting of 'Large size (120 DPI)' or Custom setting.
Workaround
Change the DPI setting to 'Normal size (96 DPI)'.
  1. Right-click anywhere on the Windows desktop and select Properties.
  2. Select the Settings tab.
  3. Click Advanced.
  4. Select the General tab.
  5. Change the Display Setting to 'Normal size (96 DPI)' and click OK. Reboot the computer if prompted.
