HOW TO
Instructions provided describe how to use an object returned from one service as an input for another service in .NET 2.0.
ArcWeb Services contains common objects, used in many web services. For example, the Route Finder Web Service implements a Geometry object, as does the Map Image Web Service.
When adding a Web reference, use the same web reference name for every ArcWeb Service added. Visual Studio then allows all of these web services to share objects.
Get help from ArcGIS experts
Download the Esri Support App
