HOW TO
Update the license file using the Update License File tool
Summary
Instructions provided describe how to update the license file with new or additional licenses using the 'Update License File' tool, when the License Manager is already installed and functioning.
Procedure
If the ESRI License Manager, (version 8.x) and the ArcGIS License Manager, (version 9.x) both reside on the same machine it is necessary to select the proper path when updating the license file using the 'Update License File' tool.
The paths for the 8.x and 9.x license managers are very similar: 8.x calls it 'License Manager' and 9.x calls it 'License Manager 9x'. Look for this when navigating to the correct Update License File.
For 8.x license managers
1. Click Start > Programs > ArcGIS > License Manager > Update License File.
2. When the Update License File tool is activated, browse to a valid 8.x license file with an extension of .txt or .lic.
3. For more details, refer to ESRI Knowledgebase article: 17889
For 9.x license managers
1. Click Start > Programs > ArcGIS > License Manager 9x > Update License File.
2. When the Update License File tool is activated, browse to a valid 9.x license file with an extension of .txt, .lic or .efl9.
3. For more details, refer to ESRI Knowledgebase article: 31357
Article ID:000008813
Software:
  • Legacy Products
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
