English
Error: stty :: invalid argument
Error Message
After installing ArcGIS Server, the following error message is displayed in the <arcgis>/servercore/.Server/configuration.log:
"stty :: invalid argument"
Cause
This error message is often caused when running stty in the C shell initialization script .cshrc or .login with a non-interactive shell.
Solution or Workaround
Remove stty commands from the .cshrc and .login files.
