English
Problem: Layout view of large ArcWeb Services map appears pixelated
A large ArcWeb Services map in ArcMap layout view appears pixelated.
Cause
The map is larger than 1000 pixels in at least one direction. The largest map allowed by ArcWeb Services is 1000 x 1000 pixels. The map is actually 1000 pixels but is stretched to fit the data frame.
Solution or Workaround
Make the data frame smaller until the image is 1000 pixels or less.
