English
How To: Use a uniform renderer for a Military Analyst DTED catalog
Summary
Instructions provided describe how to use a uniform renderer to display data in a Military Analyst DTED catalog.
Procedure
  1. A. Start ArcMap.
    B. Load the MA toolbar if it is not already loaded: View > Toolbars.
  2. Click on the 'Add MA Layer' button (green diamond with black cross) and navigate to the MA catalog in the personal geodatabase add this layer to ArcMap.
  3. Right-click on the layer in the table of contents and select Properties.
  4. A. Click on the 'Display' tab.
    B. Select 'Display rasters for selected products' and 'Use uniform renderer', if not already.
    C. Select 'Do not display wireframe at all'.
  5. Click OK to exit the Display Properties window.
Related Information
