Frequently asked question
Does ArcPad support Null values?
Answer
No, ArcPad does not support NULL values. The issue arises with the DBF tables associated with the data. The concept of NULL does not exist in a DBF. It is recommend that the user update their database design to model NULL values in a different way that ArcPad supports. For example, say the field is DISTANCE. You can introduce a CHAR (1) field called DISTANCE_NULL which is set to be ā€˜Yā€™ or ā€˜Nā€™.
Article ID:000008782
Software:
  • ArcPad Prev
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
