English
Error: Cannot implicitly convert type '[type]?' to '[type]'
Error Message
Programming in C# within Visual Studio 2005 (.NET 2.0) can lead to the following error message:
"Cannot implicitly convert type '[type]?' to '[type]'. An explicit conversation exists (are you missing a cast?)"
Cause
In the .NET Framework 2.0, C# nullable data types are denoted with a question mark. 'int' must be set, but 'int?' may be null.
Solution or Workaround
For nullable data types, add a question mark to the end when declaring it.
For example, to declare a nullable integer named test:
Code:
int test;
should be:
Code:
int? test;
