English
Error: S_insert_dbtuneTab_data(): Error insert data to DBTUNE table
Error Message
The following error may occur when running sdesetupdb2 on ArcSDE for DB2:
     S_insert_dbtuneTab_data(): Error insert data to DBTUNE table.
     ERROR in loading dbtune table.
     Error: -51
     DBMS error code: 0
     Parameter UI_TEXT of keyword DATA_DICTIONARY failed to load.
     Config Keyword: DATA_DICTIONARY
     Parameter_name: UI_TEXT
     Config_string :
     SDE schema object install not completed.
Full output when running sdesetupdb2:
ESRI ArcSDE Server Setup Utility Wed Jul 13 12:53:19 2005
Instance initialized for SDE . . .
Install or update ArcSDE schema objects: Are you sure? (Y/N): Y VERSION table created...
SPATIAL_REFERENCES table being created...
SPATIAL_REFERENCES table created...
LAYERS table being created...
LAYERS table created...
RASTER_COLUMNS table being created...
RASTER_COLUMNS table created...
TABLE_REGISTRY table being created...
TABLE_REGISTRY table created...
STATES table being created...
STATES table created...
VERSIONS table being created...
VERSIONS table created...
CURRENT_STATE_LINEAGE table being created...
CURRENT_STATE_LINEAGE table created...
MVTABLES_MODIFIED table being created...
MVTABLES_MODIFIED table created...
METADATA table being created...
METADATA table created...
STATE_LINEAGES table being created...
STATE_LINEAGES table created...
LOCATORS table being created...
LOCATORS table created...
XML tables being created...
XML tables created...
COLUMN_REGISTRY table being created...
COLUMN_REGISTRY table created...
LOGFILE_POOL tables being created...
LOGFILE_POOL tables created...
DBMS functions being created...
DBMS functions created...
DBTUNE table being created...
DBTUNE table created...
SERVER_CONFIG tables being created...
SERVER_CONFIG tables created...
DBMS stored procedures being created or updated...
DBMS stored procedures created or updated...
Error inserting following data into DBTUNE table:
 Config keyword: DATA_DICTIONARY
 Parameter name: UI_TEXT
 Config String :
Error: -51
DBMS error code: 0
 Config_string :
Cause
The links to the sde stored procedures, sdesrvfn and sdesrvsp, are not set up correctly.
Solution or Workaround
On Windows:
  • Verify that the <db2 install>/sqllib/function directory contains the %SDEHOME%\lib\sdesrvfn.dll
  • Verify that the <db2 install>/sqllib/function/unfenced directory has the %SDEHOME%\lib\sdesrvsp.dll
On UNIX:
  • Create symbolic links in your <db2 install>/sqllib/function and <db2 install>/sqllib/function/unfenced directories.
    1. Login to the server as the DB2 instance owner.
    2. Change directories to your DB2 install's /sqllib/function directory.
    3. Create the link by issuing the following command:
      ln -s $SDEHOME/lib/sdesrvfn
    4. Change directories to your DB2 install's /sqllib/function/unfenced directory.
    5. Create the link by issuing the following command:
      ln -s $SDEHOME/lib/sdesrvsp
