English
Bug: Cannot import data changes from a delta XML file where the field order in the destination is different from the delta XML file
** This issue is addressed with ArcGIS 9.1 Service Pack 2 (SP2) **
Cannot import data changes from a delta XML file where the field order in the destination is different from the delta XML file.
Cause
This is a known issue.
Workaround
Download the Service Pack from the link in Related Information section below.
    Related Information
